Freinds
I have to burn a file and the way to burn it is something like, and I quote:-
+++++++++++++++++snip+++++++++++++++++++++
"Burn in a120, burn with rmps checked, install DT4 with
vdrives disabled, and enable rmps emulation in DT4.
alternative option is mounting the image with Daemon-Tools
with securom loader."
++++++++++++++end snip+++++++++++++++++++++
I took for the 2nd option[seemed less complicated],being namely 'mounting the image with Daemon-Tools with securom loader.'
My issue is:-
I have the file(to burn) as a '*.mdf' and '*.mds' format.
I have installed Daemon tools 4.03HE(C)DT soft ltd.
What now to do![]()
is there anyone who can tell me step-wise(idiot proof) 'how' and 'what' to do from here.
Thanks for any clarification.
Kind Regards
Folks
in the mean time I think I made some progress.
I can 'mount the image' from daemon tools and point to the *.mds file. after this the Win explorer shows the icon of the software being installed. I installed the software. so far so good.
while starting up the software, it detects 'emulation software' running . so I went and did 'unmount all drives' from 'daemon tools'. this time while starting up ,the software says 'no disc found, insert the right disc'.
so basically I am in a chicken-& egg situation.
[ b.t.w In the 'emulation' option of 'daemon tools', I have checked all the options[safedisc, securom,laserlosk, rmps]. In a previous attempt , only 'securom' was checked on...but no joy.]
some help here would be really appreciated.
Thanks in advance -
What you want to do is mount the image as instructed, then open your favorite burning program and do a disc copy using the virtual drive with the mounted image as your source disc. Or you could use Alcohol 120% and burn the image without mounting it at all.
Thanks!
and if I would use alcohol 120, what should the following mean to me "install DT4 with
vdrives disabled, and enable rmps emulation in DT4. " -
Alcohol should take care of everything for you. You shouldn't have to worry about that.Originally Posted by masarada
Daemon Tools can slow rip speed
By ocgw in forum Blu-ray RippingReplies: 8Last Post: 11th Nov 2013, 12:07 -
Daemon Tools Pro 10 gives Error code 6
By Benjy in forum ComputerReplies: 3Last Post: 30th Jul 2010, 01:01 -
Help me! I can't play file *.mds file after i 'mount image' using daemon
By i_nui in forum Newbie / General discussionsReplies: 2Last Post: 19th Jun 2008, 14:04 -
HOW TO BURN Ps2 games MDF/MDS on MAC OSX
By kimkimkimmykim in forum MacReplies: 7Last Post: 2nd Nov 2007, 03:52 -
Daemon Tools for Vista
By mysts in forum Newbie / General discussionsReplies: 4Last Post: 27th Jul 2007, 20:13
